RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   DA85 (https://www.rcuniverse.com/forum/gas-engines-142/11002332-da85.html)
telejojo 03-16-2012 02:58 AM
DA85
I have a DA85 on a 100cc Yak and it runs great but the mid-range or half throttle it breaks up pretty bad,can that be adjusted out without messing up the high end?
krayzc-RCU 03-16-2012 03:34 AM
RE: DA85
what prop and exhaust r u running?
telejojo 03-16-2012 03:54 AM
RE: DA85
24x12 3 blade and stock pitts
Ih82crash 03-16-2012 04:45 AM
RE: DA85
its known as the DA burble. Get used to it for about seven gallons of fuel then it should lighten up
MetallicaJunkie 03-16-2012 02:14 PM
RE: DA85
restrain the plane, turn it on and set go to1/4 throttle or the point that burbles, and lean the low end while its running it should go away..... i bet your throttle response will improve too
