RE: Engine mount 'flex'
ORIGINAL: ahicks I think all this is pretty interesting.... would like some thoughts about something I keep thinking about. Maybe we could get away from planes for a second and talk about our automobiles? It uses rubber motor mounts to isolate engine vibration from the rest of the car, right? So take those out and replace them with steel and bolt it direct for a second. You would imagine lot's of vibration, right? Now let's install some plastic mounts. Would you imagine you would have the same vibration level as the solid mounts, more than , or maybe, just a little less? That would be my bet, a tad less, but probably not a lot. Certainly though, not more than the solidly mounted engine? Bringing this thought back to planes, wondering how the aluminum mount might differ from a solidly mounted automobile engine? Anyway, once I had the engine going I had an intense buzzing sensation (high frequency) on the soles of my feet. There is an awful lot of wood in the way, yet the vibration was quite intense. This is exactly the kind of vibration that is transmitted to an airframe when there is no isolation. Is it harmful? Probably but since I don't hard mount any of these engines on airframes, I will never know I repeated the run after the isolation mount was installed...... Vibration transmission to the deck was nonexistent. The type of mount I use and recommend is the Hyde style, rubber isolation mount. The front of the mount accepts the engine while the back is mounted to the firewall. Front and back are connected to one another via a rubber motorcycle inner tube. Over the years I've tried other, simpler mounts available commercially; they produced unsatisfactory results for isolating vibration. I didn't invent the mount; Merle Hyde did. I re-engineered it to accept stand offs |
Years ago, I used to use the Dubro isolation motor mounts a lot. They seemed to work quite well too. It was cool watching the engine at idle jiggling all around too. I don't know, I sort of got lazy and haven't used them too much since then though. But then it is tricky getting them installed in some planes, so I fell out of the practice of using them more.
Mtk,<div>Hey, thanks for not sharing your expertise or even so much as a link!:eek:</div><div>
</div><div>I've had good luck with soft mounts like Dubro on 2- and 4-strokes, as have many friends with sport and pattern birds. I still have no idea what you think are their shortcomings, nor do I care. Plz grind your axe elsewhere. </div> |
What the OP is using is a very flexible mount that is supplied with the Seagull and Phoenix ARFs. They are nylon, but not the fiber-reinforced black colored mounts that Great Planes, Horizon, and other brands have. The fiber-reinforced mounts are fairly stiff. The nylon ones from Seagull and Phoenix flex quite a bit if you push up and down on the prop/spinner (when the engine is not running, of course). The first time I was exposed to one is when I was breaking in an OS 70 Surpass (4-stroke). The engine had to run super rich at first with severe vibration. The engine mount flexed so much that I thought that something broke. But as time went on (I guess I am not as consciencious as the OP), the engine smoothed out and the flexing abated. I have 2 other ARFs with those mounts, but I am running 2-stroke glow engines with no issues.
Maybe these mounts would help if an engine is vibrating a lot, but for normal use, they are not the same as rubber-isolated mounts. You could think of them as the fiber-reinforced mounts from a vibration isolation point of view. Maybe they are better for crashes? |
An electric motor will cause alot less vibration/flexing. :)
ORIGINAL: eddieC Mtk,<div>Hey, thanks for not sharing your expertise or even so much as a link!:eek:</div><div> </div><div>I've had good luck with soft mounts like Dubro on 2- and 4-strokes, as have many friends with sport and pattern birds. I still have no idea what you think are their shortcomings, nor do I care. Plz grind your axe elsewhere. </div> |
ORIGINAL: MTK ORIGINAL: eddieC Mtk,<div>Hey, thanks for not sharing your expertise or even so much as a link!:eek:</div><div> </div><div>I've had good luck with soft mounts like Dubro on 2- and 4-strokes, as have many friends with sport and pattern birds. I still have no idea what you think are their shortcomings, nor do I care. Plz grind your axe elsewhere. </div> |
MTK:
I will not rehash old material here. Search and find if you want. Study what I teach and learn if you want. While commercial soft mounts may not work for everyone, to characterize them as 'junk' indicates a simplistic and prejudiced attitude. How do you account for their sustained popularity? I've had great success with them. Are you an engineer or vibration specialist? It just so happens my flying bud's wife works in that field, and she and her coworkers have helped him dial in his pattern planes' soft mounts. So thanks, but I'll stick with quality info from actual experts. They're pretty humble too, BTW. :) |
ORIGINAL: oliveDrab An electric motor will cause alot less vibration/flexing. :) Hahaha! That actually made me laugh! :D |
1 Attachment(s)
I use those black fiber filled nylon engine mounts almost exclusively for beam mounted engines and have never found them to be troublesome. But, I guess that's just one man's experience.
ORIGINAL: Rocketman_ I use those black fiber filled nylon engine mounts almost exclusively for beam mounted engines and have never found them to be troublesome. But, I guess that's just one man's experience. |
1 Attachment(s)
The local hobby shop didn't have the aluminum mount, so I went with the Great Planes adjustable mount. I had to hack out the center, but it should be fine. Pretty much like any other two piece mount. There is a definite difference in this mount and the 'plastic' mount that came with the Ultimate. I'm pretty confident my 'flex' will not return. :D
Thanks again for all the input! Z |
Hey, Great question! Thanks for bringing it up! Best of luck on the new install. Let us know what you see when done. -Al
| All times are GMT -8. The time now is 02:14 PM. |
