RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   DLE 111 problem (https://www.rcuniverse.com/forum/gas-engines-142/11216931-dle-111-problem.html)
Jeremymac 09-04-2012 07:34 AM
DLE 111 problem
I have DLE 111 that cuts out at about half throttle! Any ideas? I should add the motor has ran flawless with about 12 galllons thru it. It does not dead stick. It just sounds like its dying with a little power loss. It also has a good idle.
gboulton 09-04-2012 05:04 PM
RE: DLE 111 problem
To start, I'd check:<div>
</div><div>Fuel Filter/Carb Screen</div><div>Clunk line/tank plumbing</div><div>Replace Plugs</div><div>
</div><div>In that order.</div><div>
</div><div>
</div>
