DLE IGNITION
hi to all
are all the DLE Ignition are the same? here is a link for good price thanks ilan http://www.aliexpress.com/item/Rcexl...545036258.html |
RE: DLE IGNITION
To my knowledge they are. Just make sure you're buying one with the correct 10mm/CM-6 spark plug boot.
RE: DLE IGNITION
The ad in your link is for a RCEXL ignition. It is the same as the ignition on a DLE 55.
As AHicks says, this ignition will work fine on all the DLE single cylinder engines. |
RE: DLE IGNITION
Thanks guys for the answers
ilan |
RE: DLE IGNITION
I use this one on my DLE 55.
http://www.hobbyking.com/hobbyking/s...dproduct=10996 I also bought this one as a spare as it comes with an extra 10mm boot and hall sensor. http://www.hobbyking.com/hobbyking/s...s_Engines.html |
RE: DLE IGNITION
thanks for the link,thats the best price i have seen on these ignitions.
RE: DLE IGNITION
Please note those ignitions do not say Rcexl on them. They'll work most likely, and may have even come from the same place? But who knows? It's a safe bet you're on your own after the sale for sure.
More money, but with warranty: http://www.rcextremepower.net/ignitions.html |
| All times are GMT -8. The time now is 07:15 PM. |
