RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Template (https://www.rcuniverse.com/forum/gas-engines-142/11303604-template.html)
telejojo 11-20-2012 04:41 AM
Template
Avybody have a template for a DLE55 I can print off? I had one but now I can't find it.
Len Todd 11-20-2012 05:43 AM
RE: Template
I found you have to be carful when using printed templates. Sometimes the scale changes between printers, etc.. Isn't there a drawing in the back of the DLE's manual? But even the manual's template for my 111's was not to scale. It did however have the dimensions listed. I measured them out on some plywood and drilled it for a template.
w8ye 11-20-2012 06:41 AM
RE: Template
1 Attachment(s)
Here's Tower's rendition of the manual
http://manuals.hobbico.com/dle/dleg0055-manual.pdf
telejojo 11-22-2012 05:22 AM
RE: Template
Thanks....................
ForcesR 11-22-2012 07:56 AM
RE: Template
Mostmay already beware of this fact, the DLE-55 and DLE-55RA havedifferent engine mount bolt patterns.
DLE-55RA = 070mm 0
67mm
0 90mm 0
DLE-55 = 080mm 0
67mm
0 0
Roger
dadragon 11-29-2012 09:32 AM
RE: Template
Len:doing your own layout and making the templates I do my own that way I know they are rite.
