RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   engine fitting (https://www.rcuniverse.com/forum/gas-engines-142/11343285-engine-fitting.html)
top gun reed 12-24-2012 04:56 PM
engine fitting
i was hopeing someone out there could tell if the os gt55 gas engine will fit in the top filte gaint scale p-51 arf and is this engine better then the DLE 55 and how do the os 55 gas sound own the fly by http://www.rcuniverse.com/forum/js/f.../lightbulb.gif
earlwb 12-24-2012 06:32 PM
RE: engine fitting
The manual shows them using a Quadra engine on it, so the OS GT55 would fit in there even more easily. With the front mounted carb, it would be easier to hook up the throttle and you have it more exposed up front, so you can manually operate the choke as it is easy to get to, so you can flip the choke lever. You may or may not have to make new plywood spacers for the OS engine. I don't know if the wood spacers fit the OS engine or not. But that is not a problem.
The engines are all two stroke, so they all sound about the same though.
top gun reed 12-24-2012 08:06 PM
RE: engine fitting
thank:s buddy  merry  x-mas
