RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Low end problem, Taurus 2.6 (https://www.rcuniverse.com/forum/gas-engines-142/1149925-low-end-problem-taurus-2-6-a.html)
Ben Diss 09-20-2003 02:16 PM
1 Attachment(s)
I'm having a problem with my Taurus 2.6. I accidentally ran a tank of bad gas through it. I keep one gas can in my garage that I pour the remnants of stale gas into. I grabbed the wrong can one day and used it. The motor ran like crap, of course. I realized my mistake and ran good, clean gas through it and after one tank the motor cleaned up and ran good. I've since put one gallon through it.
Ever since I ran the first clean tank, I've had a problem with the low end. If I lean it enough so that I get good transition and a smooth idle, it is almost impossible to start and keep running. Once warm, I can lean it down and it runs fine until the next flight. After today's flight, I let the plane idle for a minute and killed it with the ignition switch. I then pulled the plug and took this picture. Notice the discoloration.
Any ideas what to look for?
-Ben
