3W 80 XI
I have a 3W 80 XI fairley new that when brought down to idle it goes up about a 1,000 RPMs and then back down to a normal idle. This engine ran perfect when I last flew it. I've done everything I know what to do I even made a gasket were there isn't one and still the same. Anyone with any help will be appreciated.
Thanks Soinks |
RE: 3W 80 XI
Hasen't anyone heard of or experienced a problem like this. I thought sure that someone would have chimed in and tell me my problem. I hope someone will see this and help me soon, can't fly it like this it makes it very tricky to land.
Thanks Soinks |
RE: 3W 80 XI
Soinks, I had a throttle servo that had a worn feedback pot. It gave me an erratic idle. Try changing your servo. Dan.
RE: 3W 80 XI
Thanks for the response but I disconnected the servo and used just my hand and the same thing happened but once again thanks for your advice.
Soinks |
RE: 3W 80 XI
If changing the idle carb mixture adjustment a bit one way or the other does not effect the problem maybe the ignition
is not working right at low speed, try swapping it out with another unit if possible. |
RE: 3W 80 XI
ORIGINAL: soinks Thanks for the response but I disconnected the servo and used just my hand and the same thing happened but once again thanks for your advice. Soinks <br type="_moz" /> |
RE: 3W 80 XI
i had a similar issue with my 80.... i slapped a walbro on it and it improved.... i got mine from DA..... the same carb they use on their 85
RE: 3W 80 XI
i had a similar issue with my 80.... i slapped a walbro on it and it improved.... i got mine from DA..... the same carb they use on their 85 (WJ-71)
RE: 3W 80 XI
Hi Speedracerntrixie
I don't understand how the idle stop screw could cause this problem but I would like to hear how it could . Please let me know when u get a chance. Thanks Soinks |
RE: 3W 80 XI
Worth a try for $50. Dan.
http://search.cartserver.com/search/...WJ-71&go=GO%21 |
RE: 3W 80 XI
ORIGINAL: soinks Hi Speedracerntrixie I don't understand how the idle stop screw could cause this problem but I would like to hear how it could . Please let me know when u get a chance. Thanks Soinks <br type="_moz" /> |
RE: 3W 80 XI
MetallicaJunkie
did you have to do much refitting with the Walbro? like the throttle hook up gas lines or anything else? Thanks Soinks |
RE: 3W 80 XI
i honestly dont remember...if you have easy access to the carb it should be a piece of cake
RE: 3W 80 XI
I just happen to have a new DA 100 L I wonder if that carburetor will work
RE: 3W 80 XI
RE: 3W 80 XI
Your problem sounds like a Tillotson phenomenon.
I had a 3W 150 stock carb that did the same thing even after a carb rebuild. Went away when I switched to another type of carb. Walbro seems to be good answer for the Tillotson phenomenon most of the time. |
RE: 3W 80 XI
Kmtranmd. Thanks for that advice I have a new DA 100 L that has that carb I'll try that. Do u remember any needle settings or should I just open them about one turn open and go from there. Let me know if u think of anything that u did on yours please.
Thanks Soinks |
RE: 3W 80 XI
Thanks Soinks |
RE: 3W 80 XI
Hey there,
I have a 3w80 that is exhibiting a few carb type problems and would consider the walboro carb solution if it works out for you. Let us know how it goes! Thanks |
RE: 3W 80 XI
Here is a video of a 75 having the same issue as you are. The video is after the swap.
http://www.youtube.com/watch?v=H5RxK5j3gSo |
Well I finally did it and I believe that the problem went away. It runs very smooth at low rpms I think the needles are about 1-1/4 to 1-1/2 out. Let me know if this helps.
Soinks |
