RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   G62 Engine question (https://www.rcuniverse.com/forum/gas-engines-142/1159015-g62-engine-question.html)
mitoor/c 09-24-2003 03:24 PM
G62 Engine question
I would like to get a G62 with electronic ignition already installed. Bill Bennitt of Bennitt Buile engines used to sell them. Does anyone know how to get in touch with Bill Bennett? His e-mail address would be great. Or anyone else that sells this engine with electronic ignition. Thanks Robert..
Daryl Martel 09-24-2003 04:45 PM
G-62 electronic ignition conversion
CH sells the conversion kit - it is very easy to install. I'm sure if you sent them the engine they'd install it for a small charge. I believe RCign1 (Ralph) could do the same for you - installing his ignition system of course. You hear good things about the both of them. I installed a CH system. My personal findings are the change resulted in much easier starting and smoother running from idle through midrange. Fixed advance is crude but cheap, on the other hand it's also reliable, no extra cost and you don't have to charge batteries.
Tmoth4 09-25-2003 09:12 AM
RE: G62 Engine question
Try www.bennettbuilt.com.
jimbo123032 09-28-2003 10:02 PM
I have been flying a G-62 in a 1/3 scale Extra 230 for five years now with the Cunningham installed ing. system with great results.
If you need his address I can did it up for you.
Jim
