electronic ignition conversion
hey i just converted a Murray 25cc weed eater and i really dont like having the big clunky flywheel i was wondering were i could get the magnet for the sensor and also could i just buy a dle ignition and use that or is there some special ignition i would need and how i would set up the timing on the engine i think it need to be like 20-30 degrees before tdc but i really would not know how to measure that, any help would be awesome thanks
Use Milton's video to set the timing. Dan.
http://www.youtube.com/watch?v=GBXFpxWg7vY |
Originally Posted by av8tor1977
(Post 11743493)
There you go, have fun tinkering. |
so if I buy the Zenoah G62&G45 conversion kit would that work or would I still need to find the magnet because I can machine the prop hub and all i just I need the weird earth magnet and ignition and thanks for all the great timing info also will try to post pictures if needed to show you what im dealing with ;}
+1
(Post 11743493)
