RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   C&H ignitions (https://www.rcuniverse.com/forum/gas-engines-142/11601868-c-h-ignitions.html)
larry@coyotenet 07-25-2014 07:06 AM
C&H ignitions
I have several engines with different versions of C&H ignitions. How can I tell which have auto advance timing and which do not. I have a brand new Quadra 100 with the C&H ignition, no manual advance, and it really kicks back trying to start it which makes me think the ignition does not have the auto advance.
Larry
w8ye 07-25-2014 07:16 AM
If it is kicking back, either the timing is not set correctly or it doesn't have auto advance
My experience with those is if you flip them fast enough, the kick back don't happen. If you baby them around, you will get kicked.
All Day Dan 07-25-2014 08:15 AM
Ask Adrien at CH. Dan.
http://www.ch-ignitions.com/
Truckracer 07-25-2014 09:27 AM
If we're talking about the older ignitions, all the ones I have owned that had the advance curve built in were engraved "SS" for SynchroSpark on the covers.
larry@coyotenet 07-25-2014 06:23 PM
Timing is OK so that was why I wanted to know if the ignitions were marked in any way. On a Quadra 100 you don't want to be getting your knuckles rapped too often!
Larry
Meschmidt 07-28-2014 07:18 AM
Easy way to tell is the mechanical advance ignitions are housed in a brown cover box. The auto advance came with a silver cover.
All Day Dan 07-28-2014 07:24 AM
OOPS! The mechanical advance was available in both colors. Dan.
w8ye 07-28-2014 08:12 AM
This is the way mine are
KenLambert 07-29-2014 01:40 AM
mine are marked with ss in all colors , You can take the cover off and see if the extra bord is in it if it is the brown one or can get an ad on advance module
larry@coyotenet 07-30-2014 06:08 AM
Thanks for all your replies, I have determined that the ignition does not have SS. I am going to replace it with an RCExcel unit to save the hassle, ( and to save my fingers!:D)
Larry
bcchi 07-31-2014 09:53 PM
Right Dan,The Syncro Spark module could in either cas brown or silver.If it has a timing module,should have a Syncro Spark sticker on back of case.Only sure way is to remove the case cover and see if there are two circuit boards .The larger high voltage board and smaller circuit in back of high voltage coil.Don't lose insulater card between case and HV board.
BCCHI
bcchi 08-01-2014 09:20 PM
Have bunch of ST parts do you want them,no charge .Just P&H.Not sure if I still have your mailing address.I am trying to clean out some things.Have bunch of airplanes I have to part with.Still flying when ever I can.This getting old sucks.
BCCHI
KenLambert 08-02-2014 04:39 AM
Yes I will take them and pay s&h my add: Kenneth Lambert 10000 San Leon DR #7 Dickinson , TX 77539
All Day Dan 08-02-2014 06:42 AM
BCCHI
It's still better than the alternative. Your not alone. Dan.
bcchi 08-03-2014 06:28 PM
Hi Ken,Will round them and sent them.Don't hold your breath.I am slow getting things done.We are going on a couple of trips.
BC
bcchi 08-03-2014 06:47 PM
You are right Dan,a lot of people worse off then my self.Lost most of my hearing but little hospital thing 48 days did not hurt my eyes.Can still go flying,in fact went yesterday and today.
BCCHI AMA 2500 Grumpy no two.
bcchi 08-03-2014 06:51 PM
Yes that is correct,even with the timing control you don't want to crank them whimpy or you can get whacked.
BC
