RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Converting to Gas (https://www.rcuniverse.com/forum/gas-engines-142/11606427-converting-gas.html)
cymaz 11-08-2014 10:03 AM
Converting to Gas
:confused:
I would to know please the best way to convert and engine to gas.
It is and in- line 4 cyl 4 stroke, firing order 1342.
I know spark plugs with 1/4 -32 threads are obtainable from RCexl as well as twin spark boxes. But how would it all fit together????
Cheers
w8ye 11-08-2014 11:15 AM
You can use two twin cyl ignitions.
Mount the sensors 180 degrees apart
One ignition fires 1,4 and the other 3,2
Timing is 28 degrees BTDC
Carb will likely have a rich spot about 1/3 throttle.
Run 20:1 gasoline - oil ratio
cymaz 11-08-2014 11:19 AM
Brilliant thanks..;)
