RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Plug cap falling off (https://www.rcuniverse.com/forum/gas-engines-142/11620241-plug-cap-falling-off.html)
davidej 08-01-2015 01:30 AM
I am a bit new to gas engines.
I have bought a NGH 26GT which I have mounted inverted in my new bipe. I have been conducting test/break-in runs in the garden and a couple of times the plug cap has fallen off. It has a glow plug thread miniature spark plug and the cap has a small spring inside which would tend to push it off.
The instructions are a bit scanty. Am I not pushing it on hard enough or ought I to squeeze the cap slightly to get a better grip? Or do you twist it to lock once it is on?
Suggestions gratefully received!
flyinwalenda 08-01-2015 03:01 AM
Push the cap on with some force and then turn it clockwise about 1/4 turn and it will "lock" on.
dirtybird 08-01-2015 06:50 AM
be sure the plug is in tight or you will be unable to remove the cap.
davidej 08-02-2015 06:07 AM
Thanks for your help _ I thought that might be the answer.
a pity it is not mentioned in the instructions
