Fuji Gas 43/50 Engines..
I have three of these Fuji's and I like them.... The problem of course is getting parts.... I need parts of any kind for these engines so that I can repair if needed.... What I need now is Carbs with the insulator block or just the insulator block.... I also need an EI module in good shape for these 43/50 Fuji engines... Since we do not have a source for these parts new from hobby companies I am looking for anyone that has these engines so that I can use them for parts.... If you know of anyone I would appreciate letting me know how to contact them... Hopefully someone, somewhere, in computer land has parts new or used.... so Thanks.... Richard
Thanks..... looks like a good way to go if I can not find an OE part for my Fuji....
I had my 34 Fuji converted to a C&H ignition which works very good.
If you got some phenolic material probably wouldn't be to hard to make your own insulator. |
I have a couple Fuji 50's, they both run and run very well when I last used them. I have not thought about spare parts. What do you need? I do have some parts. Post what you need.
Rich |
I can use two insulators and/or carbs...... one for the 43 and one set for the 50... and one electronic ignition...Thanks and let me know if you have what I need....
