RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   RCExcel Ignition Module (https://www.rcuniverse.com/forum/gas-engines-142/11658691-rcexcel-ignition-module.html)
golf4two 01-01-2019 03:04 PM
Does an RCExcel ignition get hot/warm enough to require cooling air during normal operations? (DLE35RA)
On my newest build I currently have it in a wedge shaped box underneath the motor box. Sorry no picture right now as there are lots of screws and panels to remove just for that.
Also, will double-stick tape keep it in place, at least until I can figure a way to drill some holes so I can use a couple of ZIP ties?
TIA.
G42
Lifer 01-02-2019 01:19 AM
In my experience, no cooling air is necessary. Mine are typically wrapped in foam and are behind the firewall. Most flights are 10 minutes or so and no adverse reaction noticed.
ahicks 01-02-2019 04:42 AM
If mine are located ahead of the firewall, it would definitely have zip ties securing it.
