RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   3 Blade Prop Clocking? (https://www.rcuniverse.com/forum/gas-engines-142/11680069-3-blade-prop-clocking.html)
ezflyr 06-27-2020 06:26 PM
Hi All,
I need to drill a couple of 3 blade props for the DLE-55. Where should the prop be clocked with respect to the compression stroke? These engines will mostly be spun by a starter, but I may start by hand occasionally.
ahicks 06-29-2020 03:32 AM
I would find a 2 blade that's been properly "clocked" and identify the prop blade that's at 2:00 when the engine is coming up on it's compression stroke. Then lay that blade over one of the 3 prop blades and reference the already drilled 2 blade prop holes to mark the 3 blade.
UNLESS this were a DLE 30-35. With one of those I would go with a single bolt prop adapter and forget drilling and/or indexing.
