Ignition Problem/Question
My DLE 20cc died on the landing roll out. I refueled and tried to start it. But it wouldn't start, not even a pop. Judgeing by what was coming out the exhaust it's seems to be getting fuel. I'm thinking no spark. So I took out the ignition and hooked it up to basic RCEXL ignition tester with just an LED and an RPM rheostat. When I hook up the battery I get a single spark and that's it. I don't have instruction for it other than it says a solid led means it's hooked up right. I get the solid red an a single spark but no multiple sparks. Does this mean the ignition is bad? Does anyone know of a link for it's instructions? Thanks for any info.
https://cimg8.ibsrv.net/gimg/www.rcu...57bd659094.jpg Thanks for any info. |
Check YouTube. You might find what you need.
I keep a spare cm-6 ignition system on hand always. If an ignition system is bad, you have the replacement handy. If not, you still have the spare on hand. Just my 2 cents worth.
Originally Posted by Lifer
(Post 12698010)
| All times are GMT -8. The time now is 03:42 AM. |
