Not sparking every rotation
I have an issue trying to start and keep running my 3W 80 with rcexl ignition unit.
If i manage to get it running it runs fine at top end and will tick over for a short while but then die. Upon investigation I've found that it sparks on some revolutions but not others. I've tried different ign units and different plugs and no difference. Also the pick up is brand new Any thoughts welcome |
Originally Posted by vease
(Post 12770313)
(Post 12770313)
must admit that i'm only spinning it over by hand so maybe that the issue. Its just that when running and ticking over and suddenly dies, its like it doesn't spark for a rotation.
maybe i need to check the timing again and fuel feed Cheers |
(Post 12770357)
(Post 12770313)
If i manage to get it running it runs fine at top end and will tick over for a short while but then die. Upon investigation I've found that it sparks on some revolutions but not others. I've tried different ign units and different plugs and no difference. Also the pick up is brand new Any thoughts welcome when was this engine made? single or twin? what ignition was it supplied with? what prop do you have on it? The reason for most of these questions is the old ignitions for 3W's were not driven by hall effect sensors. All our arms got tired one day trying to start a 3W that had been changed over the winter by the new owner. He just screwed the hall effect sensor in the holes for the old sensor. I put the prop at TDC to quick eyeball the timing and boy was it off. I unscrewed the sensor ziptied it in about the right place and the motor ran great. So sensor brackets are now available for older engine conversions (just if that is the case). Other reasons I will think about for awhile. |
I would try to readjust the low end needle and check rpm with a tack. Maybe your just trying to run it at to low of rpm?
(Post 12770357)
