RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   help with 3W75 -can install (https://www.rcuniverse.com/forum/gas-engines-142/1270064-help-3w75-can-install.html)
2rolls 11-11-2003 08:04 PM
I have a 3W75i mounted inverted in a WH Giles.
I want to replace the Johnson Pitts muffler with a more quiet system.
Is there any way to connect the inverted engine to a can located in the belly of the fuse?
Flexable pipe?
Special custom header?
Any ideas?
thanx...croz
cap10b 01-03-2006 08:25 PM
RE: help with 3W75 -can install
Hey 2rolls,
I too have a WH Giles with a 3W-75I rear carb and wanted to run cans, after talking to Tom about it you need to contact him direct.
He knows how to install them but its really a hassle. From what I gather you have to nearly tear the airplane up to get it done. Tom said its not worth it.
Best of luck to you.
JDS
vatechguy3 01-03-2006 09:30 PM
i don't know about fitting a can inside that plane, but the header you're looking for is called a wrap around header.
tony
