RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   cactus aviation?3W?PROBLEMS? (https://www.rcuniverse.com/forum/gas-engines-142/1287128-cactus-aviation-3w-problems.html)
gravityrulz 11-18-2003 12:49 PM
3-w 100 been baaaaaack to CACTUS 4 times and 3 planes later and he says he has it fixed again. Engine wont stay running after about 30 flights. Any one have any thoughts on this subject?
Flyfalcons 11-18-2003 12:54 PM
RE: cactus aviation?3W?PROBLEMS?
There is an answer. Read this thread all the way through and see how Otter fixed his problems.
http://www.rcuniverse.com/forum/How_...1118749/tm.htm
gravityrulz 11-18-2003 05:53 PM
done all of that, he says the reed block is warped
Flyfalcons 11-18-2003 05:55 PM
Otter fixed the problem by going DA.
gravityrulz 11-18-2003 06:22 PM
thats a sure cure, i bought 2 of em. DA that is
Kris^ 11-19-2003 08:26 PM
I did a "How-To" writeup on modifying the DA carb block to work on the 3W engines. . you might look up the thread and give it a try. A guaranteed FIX for your problem.
Here's the link:
http://www.rcuniverse.com/forum/m_12...tm.htm#1258909
