RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   bme102 (https://www.rcuniverse.com/forum/gas-engines-142/1420061-bme102.html)
rcnutmd 01-11-2004 05:21 AM
bme102
i just purchased a bme 102 but i got the spinner backplate on the prop on the alum. prop washer on another washer and the bolt to tighten all down but there is no room on the shaft to put a double nut on any suggestions.
-acro- 01-11-2004 06:00 AM
RE: bme102
The threaded rod you have your prop nut on is extendable.It is just a piece of rod with a lathe dimple at one end and hex key insert at the other.It is probably lock tightened in place, so double nut it and back it out to desired length.It is best to verify that you will still have a min. of say 1/2" still threaded in the main ,than lock tight it in place again.
Good luck, Bill
rcnutmd 01-11-2004 06:05 AM
RE: bme102
so what you saying is i can back out the shaft to double nut it and thread lock the shaft in place at that position ? do i need special tread lock or can i just use z42 thanks
-acro- 01-11-2004 06:36 AM
RE: bme102
Yes,and any good thread locker will do ,you just want it to stay where you put it. If it comes loose so will your prop.
rcnutmd 01-11-2004 06:39 AM
RE: bme102
thanks for your help john
Geistware 06-18-2004 06:29 PM
RE: bme102
Would it be better to remove the rod and install a bolt?
Just a thought, and with my spinner (CF) may be easier!
