RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   BME What Prop? (https://www.rcuniverse.com/forum/gas-engines-142/1482423-bme-what-prop.html)
Floater-RCU 01-30-2004 03:41 PM
BME What Prop?
Hey guys, Jemo? DGrant? What prop have you guys found to work best on your BME 50?
Floater.:D
Jemo 01-30-2004 03:47 PM
RE: BME What Prop?
22x8 or 22x10
Right now I am using a MSC 22 X 8 (RPM ?? Don't remember, don't care)
and it pulls like a tractor, I think I like it better than the 10.
Other brands will give different results of course.
SMALLFLY- 01-30-2004 04:10 PM
RE: BME What Prop?
I like the mejlik 22-10 the best. I have run mine with a zinger pro 22-8 and had good results as well.
The BME 21-10 works well if you need a bit more prop clearance
Floater-RCU 02-09-2004 10:59 AM
RE: BME What Prop?
Thanks for taking the time to answer guy's, I bought a Menz s 22-8 and I think I might try the Bambula 21-8 or 22-8.
Floater.:D
Scott Claboe 02-09-2004 11:47 AM
RE: BME What Prop?
I use a 21-10.
Sailor 02-10-2004 09:24 PM
RE: BME What Prop?
I have a Zinger Pro 22x10 on my BME .50 with ten flights on it. This motor is on a Hangar 9 80" CAP 232, and right from the get go, it would rocket with unlimited vertical. I didn't even bench run the engine first, as BME recommends breaking them in while flying. Have Fun!
