RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Bench testing DA50 needed? (https://www.rcuniverse.com/forum/gas-engines-142/1631661-bench-testing-da50-needed.html)
nonstoprc 03-16-2004 07:30 PM
I am thinking about bench testing the engine for the purpose of getting myself familiarized with the beast. Do you guys do that? If so, what should I pay attention to?
JohnVH 03-16-2004 07:35 PM
RE: Bench testing DA50 needed?
You can if you want to, I dont bench run anything, bolt it on, fire it up, see how it runs, fly it.
Mike Bogh 03-16-2004 11:26 PM
Only do it for fun...it's by no means necessary.
I have a couple of friends who were going to bolt theirs to opposite sides of a table, then see which one would pull the best...again, all in fun.
They changed their minds and bolted the engines on their planes...should be ready Sunday I'm hoping...
deputydog 03-16-2004 11:45 PM
Put it on a plane, start it, check low end then hi end and FLY IT! Its better for the motor in the air. Good luck!
RickP 03-17-2004 08:27 AM
Naaa,
We bolt them right up here, fuel them up and start flying them. Just hold off on the TR'n and Harriers for a few flights so you don't over heat her ;)
RickP
GoeKeli 03-17-2004 10:59 AM
Nonstoprc,
I just mounted my 50 to the plane and ran a tank at home on mid throttle then took it to the field and am now in the 3rd gallon of break-in gas. I agree with all who say the cooling is better. It got a bit warm on the first few runs and I was glad it got as much cooling as it could. I also agree that in the early time just sport/imac stuff is perfect for break-in. I really like this engine. !~)
Joe
Rwoody 03-17-2004 11:02 AM
The only reason for bench running is to establish the starting procedure, so you don't look dumb at the field. The other is to astablish a good pois. idle so you don't crash and burn on take off. When you buy a weed eater or chain saw, you put gas and oil in start it up cut away at full rpm. & there is less air moving over the fins then in the air. Do it in the air!
