Fuji 32b Tap for Smoke
Where should you tap the case for Fuji 32b for bennett smoke setup?
By the By, my Fuji 32 popped on the 3rd flip right out of the box and started on 4th flip. After an hour of 25:1 Klotz it idles @1350 and top ends a Zinger 18-8 @6900 to 7000. You really gotta take your time and adjust the low needle. Ended up turning it out about 1 1/2 turns. It seems to be all about the prime. If it not really wet it wont start. Also, I have the prop set so when it is at 12:00 magnet are just before the pickup. If its cold, I choke it and open the throttle all the way. I turn the prop through about 20 rotations to prime it. If it don't start after 3 flips, I prime it some more. Anyway, I'm hoping to have a lot of fun with it on a Ultra Stick 120 (not the lite). |
| All times are GMT -8. The time now is 03:51 PM. |
