g-23 help please
I have a G-23 that ran fine earlier in the day-got home and had to tighten the muffler-removed prop and cowl and double check everything-Now I cannot get it to start-any ideas?=I was reading the manual and I have the prop set parallel with the wing at the start of the compression stroke-plenty of fuel-primed it and and wet my finger and no luck-I have put the dynatron starter on it and it still will not kick off-thanks
RE: g-23 help please
Take the spark plug out and check for spark. Talk with you tomorrow....Capt,n bed time
| All times are GMT -8. The time now is 02:32 AM. |
