engine problems
i am using a 18cc weed eater for a rc boat motor and i need to know how to make the shaft work for a boat. and what i need to get it turning to get the engine going because i broke the pull starter?
RE: engine problems
Couldn't you just fix the pull starter?
RE: engine problems
would a recoil starter from an rc car work or be easily modifiable?
RE: engine problems
You need to fix the pull starter!
A car engine pull starter (.21 size) will NOT work. |
RE: engine problems
Some of the lawn shops will fix you up with a good secondhand one, or maybe repair the old one cheap (if it's not too bad).
| All times are GMT -8. The time now is 06:56 AM. |
