BME 110Xtreme prop?
What's the prop of choice for the 110xtreme?
RE: BME 110Xtreme prop?
I'm liking the Mejlik 28x10 and the Air Wild NX 28x10 with the Air Wild getting a slight nod.
They're hauling my 30 pound Wild Hare Extra in FINE fashion! |
I am gonna have some ground clearance problems with a 28" prop. I can do it but a 27" would be better. Have you tried any 27" props? I am flying a 26lb h9 sukhoi and right now I am using an air models 26x12 3blade. I am looking for something a little more efficient. Maybe a little more rpm and quicker spool up. The 26x12 3blade is giving me 5950 rpm warm running lawnboy ashless 32:1 for break in. Thanks.
A mejlik 27X10 generates pretty much the same load as the 28X10, so the 27" is the one. I have a 26X12 mejlik on my Brison 6.4 and there's just too much forward speed so I went with a Biela 26X10, but haven't tried it yet.
You may want to try a Mejzlik 25x12 3-blade. My 3W-106 on in-cowl Johnson mufflers turns it around 6200 rpm. Works very well on a 28 lb WildHare Extra.
| All times are GMT -8. The time now is 01:55 PM. |
