Wet ignition module
I was out this evening, testrunning my new DA100.
We were interrupted by a local rainshower, during which the engine and ignition module got wet. Afterwards tha DA wouldn't start, and the ignition module was emitting a high pitched tone. Can the iginition module be damaged ???? |
RE: Wet ignition module
It can be damaged, remember that there is 25,000v running around inside. HV and water don't mix well.
Try a long soak in alcohol and then let it sit in the sun for a few hours |
I had an RCS ignition modual emit a high pitch sound new out of the box. It did'nt work or generate a spark. ad to send it back for a replacement. Sounds like the same with you. You should send it in and have them look at it.
Gunny |
Yau'll got KFC there ? You can take it to them and see if they can sell it for you because-it's FRIED ! :)
Send it in for a rebuild. |
| All times are GMT -8. The time now is 04:45 AM. |
