RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   DA50 Spinner Bolt Thread Size?? (https://www.rcuniverse.com/forum/gas-engines-142/2035941-da50-spinner-bolt-thread-size.html)
lsnover 07-29-2004 06:18 PM
Does anyone know the type/size bolt for attaching a spinner to the DA50s prop shaft?
Lee Snover
Antique 07-29-2004 06:29 PM
RE: DA50 Spinner Bolt Thread Size??
should be in the instructions, probably a 10-32..[8D]
lsnover 07-29-2004 07:54 PM
Not that I could find, that's why I asked. ;-)
Regards,
Lee
RobertC 07-30-2004 02:01 AM
It is 10-32. Not that I read that anywhere, but I purchased a TruTurn spinner that claims to come with a 10-32 bolt... and it fit the DA-50 perfectly! I was worried that I would need some crazy adapter but it seems just fine as-is.
Jemo 07-30-2004 06:38 AM
It is 5mm
lsnover 07-30-2004 08:04 AM
Thanks guys:
Guess I'll have to check with DA to clear up the confusion. ;-)
Regards,
Lee
mdavies31 07-30-2004 10:33 AM
Here is my email to DA and Daves response.
What bolt size, 10/32 or 5MM, are the prop bolts and
the spinner bolt on a DA50-R.
Hello
They are 5mm but 10/32 works fine for the spinner cone.
Stick with 5mm for the prop bolts.
Dave
lsnover 07-30-2004 10:44 AM
I have bolts for the prop, just need one for the spinner.
Lee
greenboot 07-30-2004 09:13 PM
Finding out a 3/16 bolt will fit where you really need a 5mm is one of the things that really makes life wonderful.
Tom
Antique 07-30-2004 10:37 PM
It will work for the spinner bolt, but a 10-32 is about .006 smaller and will strip out if you use one in a place designed for a 5mm, like the prop bolts...
I gotta ask Dave why an engine made in Arizona, USA, uses metric bolts...:D
Yes, some of the parts are made elsewhere..The crankcases are made from 7075 aluminum in Tucson, AZ...To the best of my knowledge the ONLY model airplane engine cases made on a CNC machine from 7075, the best and most expensive aluminum alloy, not from CHEAP POROUS castings like some other engines...
NO, not all engine cases are CHEAP and POROUS...:D
P-51B 07-31-2004 03:42 PM
ORIGINAL: RCIGN1
Why not? The rest of the world (ie market) uses metric sizes.
Antique 07-31-2004 05:14 PM
I'm 69 years old, been a machinist and using inches all my life, this is the USA, the rest of the world can KM:D
P-51B 08-02-2004 12:29 AM
Well, they say you can't teach an old dog new tricks, but I guess those that realize the new tricks lead to more reward are happier.;)
I prefer to divide by ten rather than figure out how many pecks are in a gross of bushels. Or how many ounces in a hogshead!:)
I'll take DA quality with the metric...or without![sm=thumbup.gif]
Antique 08-02-2004 12:40 AM
You got that right :D
