RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   EIS Conversion Compatible with BT-50SA (https://www.rcuniverse.com/forum/gas-engines-142/2206527-eis-conversion-compatible-bt-50sa.html)
hilleyja 09-27-2004 12:51 PM
Bax,
Is the new Fuji EIS Conversion Kit BT50 compatible with the BT-50SA?
Bax 09-27-2004 12:59 PM
RE: EIS Conversion Compatible with BT-50SA
The EIS will bolt onto your BT-50SA, but you will have to carefully drill and tap one hole. On teh BT-50 SA, one of the mounting bosses isn't drilled and tapped.
drdoom 09-30-2004 02:35 PM
This is a pricey conversion. Is it worth it. I have the electric starter on mine. and I have to say sometimes it is difficult to start unless the starter is really spinning it.
Dennis Calvin
drdoom 10-07-2004 04:00 PM
Tower carries the conversion kit make sure you buy the conversion and not just the EI unit.
It is currently on back order.
