RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   prop hole diameter??? (https://www.rcuniverse.com/forum/gas-engines-142/2210475-prop-hole-diameter.html)
sgtshultz 09-28-2004 06:27 PM
what is the prop hole size for a G23? please
suraerobatics 09-28-2004 10:19 PM
RE: prop hole diameter???
im not sure of the exact dia what i did is just reemed it out untill it fit snug on the hub
i do know the best prop for that motor is a 15x7 or a 15x4 prop what plane are you going to put it on ?
sgtshultz 09-28-2004 11:08 PM
was told it's a 5/16
thanks
ScottK 09-29-2004 06:03 AM
Prop shaft on G23 is 8mm.
