RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Tuned Pipe Coupler Material (https://www.rcuniverse.com/forum/gas-engines-142/2746989-tuned-pipe-coupler-material.html)
martyg 03-09-2005 07:42 PM
What type tubing is used as coupler between header/pipe on gas engines?
Won't the blue silicone stuff for glow melt in a gas application?
What is a good source for the right material? I need 7/8" ID.
w8ye 03-09-2005 11:14 PM
RE: Tuned Pipe Couper Material
MACS only sells up to 3/4". I think it's all blue? The 3/4" was supposed to be good for 62cc.
Enjoy,
Jim
majortom-RCU 03-10-2005 05:55 AM
McMaster Carr -- http://www.mcmaster.com/ -- has silicone and teflon tubing rated to 500˚, wide range of sizes, reasonable prices, excellent service.
stomper 03-10-2005 08:19 AM
Heres the stuff I use >
http://www.aerotrend.com/shop_subcat...2a4275598e2673
And I use this for glow engines >
TJ Moran 03-13-2005 07:24 PM
RE: Tuned Pipe Coupler Material
I have been successfully using a High Temp Exhaust Coupling sold by Octura Model Marine Supplies for connecting tuned pipes to headers on 2-strokes. It doesn't last forever, but it outlasts anything else I've tried. It appears to be a sort of red rubber silicone that has about 4 layers of fiberglass woven reinforcement imbedded in it. They sell it in 3 inch lengths, and local hobby shops who sell stuff for model boats usually will carry it or can get it. It is available in inside diameter (inches) sizes 1/2; 5/8; 3/4; 7/8; and 1 inch. Their part numbers are OC16HTEC, OC20HTEC, OC24HTEC,OC28HTEC, OC32HTEC.
I think the part numbers are the I. D. in thirty-seconds of an inch and HTEC stands for High Temperature Exhaust Coupling.
You acan find it listed on http://www.pirespreto.com/octura_catalog.htm.
I couldn't find a web page for Octura
but - their address is
Octura Models, Inc.
7351 N. Hamlin Ave.
Skokie, Ill 60076
TJ
Tri-stan 03-13-2005 10:16 PM
Contact Desert Aircraft or Aircraft International and ask them for some Teflon couplers. Both places have them in 22mm (7/8") and 25mm (1") diameters.
Kris Welter
stomper 03-14-2005 06:48 AM
Hey.... how are you doing Kris? It's been awhile.
