RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Electronic ignition kill switch (https://www.rcuniverse.com/forum/gas-engines-142/2752424-electronic-ignition-kill-switch.html)
ini 03-11-2005 07:23 AM
Anyone used this:
http://www.rcatsystems.com/pdf/rc100_datasheet.pdf
Doesn't this cause radio problems as radio & ignition are not separated?
ini
branded 03-11-2005 08:28 AM
RE: Electronic ignition kill switch
Which one are you questioning? There are three models, one of which states that its optically isolated (RC100FO).
If you use that one you'll have no problem.
bob_nj 03-12-2005 07:37 AM
I've been using the RC100 shown here -> [link=http://www.rcatsystems.com/rc/electronics.php]RC100[/link]
for a couple of seasons now in a 40% Cap, and it's been flawless.
They know theri stuff_bob
ini 03-12-2005 03:42 PM
I meant the rc-100 that is shown in schematic (bottom of page).
Thanks for response.
ini
iluimu81 04-02-2005 09:08 PM
Hi,
I have a pull start engine and it doesn't need battery for the ignition. Does this kill switch work for this type of engine or it has to have the ignition battery for the RC100FO to work? Thanks, Victor
