Supersonic Mufflers
HI
Has anyone tried the Supersonic mufflers with the baffle installed on a 3w or DA 100? I am not sure I want to tackle retro fitting a set of canister mufflers into the glass fuse, but I do want something a little more quite then my Johnson mufflers ;) Also anyone using canisters without a tunnel in the fuse? Thanks Charles |
Supersonic Mufflers
have the 3w150ts and the supersonic is not as noisy and you
can hear the prop noise verses the exhaust. Dont't get me wrong that they are really silent, they are just not as bad as the johnson. Hope this helps tony |
Supersonic Mufflers
I was talking to AI last week about some parts for my 100 and was told that supersonic has started to put an insert into some mufflers that is an improvement over the ones without the insert. I was just wondering how much the insert helped.
Charles |
Supersonic Mufflers
Can you get more performance from the supersonic then the J & A?
| All times are GMT -8. The time now is 11:16 PM. |
