Jersey Modeler ?
For those that are using the Jersey Modeler fuel cans..When you de-fuel your plane, what keeps you from back-flushing all the junk back into the can? Im talking about the ones with the hand pumps..
RE: Jersey Modeler ?
Since the fuel can is filtered, how much junk would have gotten in the tank in the first place?
I see your point..I guess Im trying to avoid pumping it back into the can if possible..
There really is no reason to empty it out as far as I know. There's no moisture issues like glow and if you plug up your vent you can rotate the plane in any position when transporting it from your vehicle to the house. I guess for long term storage it would be better to empty the tank.
marty |
ORIGINAL: afterburner There really is no reason to empty it out as far as I know. There's no moisture issues like glow and if you plug up your vent you can rotate the plane in any position when transporting it from your vehicle to the house. marty |
What I do is not worry about junk being pumped back into the can when I take fuel out of the plane. The filter works both ways, and once I'm done, I pump a few turns back into the can to flush the filter so anything that got stopped by the filter is then in the can. When I fuel the plane, the filter removes any junk for me.
HTH Jim |
I didnt realize it is a 2 way filter..Makes sense now..thanks
| All times are GMT -8. The time now is 03:58 PM. |
