HELP!
Anyone know of a source for an "Onboard, TX controlled, E-switch" for shutting down a magneto ignition engine?---I use "Jomar" E-switches on my battery ignitions, but they don't work with magneto systems---I have been told they don't like AC voltage---All I know is that they keep the mag shut/down circuit grounded all the time, no matter the switch position---
Thanks Ed |
RE: HELP!
Seems like a small micro switch glued on the top of a servo triggered by a round servo wheel ground to a cam would work to ground out the mag..It worked on RC assist free flights years ago to open the battery circuit....:D
RE: HELP!
Hi Ralph!---Yea, I was just trying to get away from a mechanical set/up & hopefully do it with solid/state electronics---like my battery ignitions---Thanks tho for the idea!---
Ed |
RE: HELP!
Well-Well, it looks like maybe this is what I'm looking for! http://www.rcatsystems.com/rc/electronics.php
It says that it works with magnetos--- |
RE: HELP!
I use those from RCATS
they work very well for mag, or electronic ign |
| All times are GMT -8. The time now is 10:27 PM. |
