RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   information about an engine (https://www.rcuniverse.com/forum/gas-engines-142/2917406-information-about-engine.html)
nealt870 04-26-2005 08:55 PM
I just bought an extra 300 with a 4.4 infinity gas engine. Does anyone know where I can get some info. about this engine. I've tried Yahoo search engine and it came up with nothing.
Antique 04-26-2005 10:05 PM
RE: information about an engine
If it's a 4.4 it must be a Husqvarna conversion..Can't be too bad if the crank and cylinder are original Husky.....
Someone once made a 4.4 engine with a machined case, that had a reed valve on the bottom of the case....The original piston port intake port was covered with a plate and the cylinder was opened up all the way to the bottom to use that as an extra transfer port..Worked well, buth the sharp edges of the cylinder wall would cut into the piston ring...If yours is one of these it would be a good idea to slightly round off the sharp edges...:D
captinjohn 04-26-2005 11:17 PM
Please post a photo of this Infinity gas engine. Thanks Capt,n
