RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Gas Ignition Problem (https://www.rcuniverse.com/forum/gas-engines-142/3002771-gas-ignition-problem.html)
Razorback58 05-23-2005 11:22 AM
I have a BME 44 that I'm having a slight problem with. The cowl has rubbed a hole into the plug wire, and now I think that I'm getting radio interferrence from this. Is there a safe way to fix this, or do I need to replace the ignition box? It has the C & H ignition on it. I've used electrical tape, but I still seem to be getting a little interferrence. Any suggestions? Thanks!
Geistware 05-23-2005 01:59 PM
RE: Gas Ignition Problem
Send the unit into C&H and have them to test it and replace the wires.
I had mine done and it cost about $35 per wire.
solkie88 05-28-2005 10:54 AM
i seem to be getting some type of interference from my bme 50 gas engine... i have it grounded to the engine and motor mount.... if anyone can help i would greatly appreciate it... thanks
ryan
Geistware 05-28-2005 10:58 AM
I would ground it to the engine jug only and not the mount.
It should be as close to the plug as possible
ORIGINAL: solkie88
ryan
