RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   carb problems (https://www.rcuniverse.com/forum/gas-engines-142/3062348-carb-problems.html)
Hawk21 06-10-2005 08:14 PM
carb problems
Well I started my engine trying to get a rich mixture but with out success
As I keep opening the high speed needle i did not noticed the engine getting rich
The low speed needle was open and the engine run rich at idle
Does some one knows what makes this problem??
I did almost get the high speed needle out and the engine did not got rich at full throttle
Thanks for your help
pinkpig607 06-10-2005 08:27 PM
RE: carb problems
your low speed nedel neeeds to close a littel just al littel
Hawk21 06-10-2005 08:41 PM
RE: carb problems
the problem is that I cant get the engine rich at full throttle
and i opened the high speed needle almost all the way out
mstroh3961 06-10-2005 09:16 PM
RE: carb problems
Is this by chance a DA-50?if it is here is some interesting reading.[link=http://www.rcuniverse.com/forum/m_2978513/tm.htm]click me[/link]
RTK 06-10-2005 09:54 PM
RE: carb problems
What engine and what prop? Sometimes over propping leads to a less responsive high needle.
Hawk21 06-10-2005 11:46 PM
RE: carb problems
it is a bme 110 with a menz 27x10
pe reivers 06-11-2005 04:01 AM
RE: carb problems
Open the idle needle more. This needle also supplies fuel at WOT.
It may mean you have to fly using an extra rich idle, but that is better than having a lean top end.
Flypaper 2 06-11-2005 05:30 AM
RE: carb problems
Make sure the filter screen inside the carb isn't plugged.
RTK 06-11-2005 10:00 AM
RE: carb problems
Hawk- I have a BME 110 and I know what you mean. You can unscrew the needle 4 or more turns and it will never become slobbering rich.
Just to be sure so you don't damage the engine trying on the ground to richen it up. Send Keith an e-mail. This is the fastest way to get a response from him, but First check the filter screen like flypaper said. If you can peak it and back off a couple of hundred rpm you should not be to lean.
What rpm are you getting? Is it sagging in up lines?
Ralph
Hawk21 06-11-2005 12:41 PM
RE: carb problems
I will never buy another bme
the service was terible in fact the engine was send back 2 times
and never solve anything
But finaly everything looks good I drilled out the high speed fuel passage going in thru where the high speed needle threads in, using small bits and a pen vise. The drill I use was a .059 inch
Now the engine has enough fuel
I tack it at 5820 with a 27x10 menz still a little on the rich side
Thanks to every one for the help
Benny
RTK 06-11-2005 02:42 PM
RE: carb problems
Sorry to hear of your service problems.
I have had nothing but the best service from Keith, Although it is very hard to get him on the phone. I usually e-mail him and have received all my responses with in 1 day.
I also PM'd you Benny
Ralph
tflame 06-11-2005 09:17 PM
RE: carb problems
Hello benny
I`m glad that the problem is solved. I have seen you work hard on setting that BME 110 for the past year and all the hassle you have been thru with BME and for my P-51 Mustang I will be buying a ZDZ. I think BME doesn`t care much about how their product performs after they have your money they should have been the ones that should have solved this problem after all you had sent it back to them twice!!!!!!!!!!!
Yours
Tflame
RTK 06-11-2005 11:02 PM
RE: carb problems
Tflame-
After I made my last post I e-mailed Keith asking about this and how mine is somewhat similar but not to this extent. I still can make it rich, just not the usual slobbering rich if I crank out the needle.
Within a matter of hours he replied and has another approach that will work also. He asked me to pass along this information.
The best cure is to raise the fulcrum arm that opens the needle about 1/32 of an inch. This will let the carb pump more fuel and get slobbering rich at about 2.5 turns out. Please share this information with anyone you know with a 110.
Thank you
Keith
BME
Hawk21 06-12-2005 01:00 AM
RE: carb problems
Thanks Tflame for sharing your knowledge with me
and help me getting this thing running right hopefully it will fly tomorrow
if the weather is good
RTK, the drill I use for the final for was a 0.059 inch I did use a smaller one before that
well Tflame did he is the man when it comes to engines no one matches his knowledge, do not know the exact measure I think it was a .053 or .056 will let you know
later. Remember this are small bits and need to be very careful so that they do not break inside
I will not go with the 0.059 at first.
Benny
