King 100 Ignition Problem?
I hope somecan help me. We have a 100cc King engine which, although a few years old, had never been started until today.
After adjusting the H&L settings we have managed to get the engine to start and tick over up to about ¼ throttle nicely. The engine has been fitted after market with a CH Electronics ignition system, with mechanical advance retard linked to the throttle. i.e a throttle coupled spark advance (TCSA) system When the throttle is advanced above ¼ it starts to hunt and will not hold its rpm. any suggestions on whether its the ignition set up or the engine itself and how to go about identifying it? cheers |
RE: King 100 Ignition Problem?
HI, YOU STILL HAVE THE KING 100 CC? OZYRAY
Probably the ignition timing off a little combined with an old carb diaphragm that needs replaced.
the engine is actually Pittspecial - who you've been corresponding with
| All times are GMT -8. The time now is 07:54 AM. |
