DA 100 No manual need factory valve settings
I purchased a DA100 used and have no manual, I know i could call DA but they are closed, could someone please let me know what the factory needle settings are, I can fine tune from there
thanks |
RE: DA 100 No manual need factory valve settings
Without having a DA100, but having a Brison 104, I'm guessing 1 turn open for the low and 1-1/2 for the high. I believe it's the same carb and reed.
This topic has been done uncounted times. "Factory" settings are just an educated guess...If you start with 2 turns out and set the high first you can not go wrong..The guy at the factory can't set it any better than you can with your prop and at your altitude with your fuel mix..[8D]
thanks for the info, backed them out 2 turns then reset, seems to run OK
