Moki gas conversion?
I did a search in this forum and found that Moki has a gas conversion. Does anyone know who makes this conversion? How about using it? What size engine are they converting?
Thanks Scott |
There are 2 different "Moki" engine companies with the same name produced in the same country (Hungary). One produces glow engines distributed in the US by Horizon (1.35, 1.8, and 2.10"). The other produces gasoline motors sold in the US under the badge of RCS (RCShowcase). They are sold in the UK as Mackay and in Germany as Moki - isn't that confusing. The Moki gas engines are not conversions of the Moki glow motor - totally distinct designs from the ground up. I don't know of any conversions of the Moki glow motors. I doubt it would be worth the cost to convert considering there are plenty of gas ignition motors on the market that cost only a little more than the Moki glow motors.
Mokis
The glow Moki makes a great gasser when the conversion is done right. BUT by then you will have $500.00 in it. There are LOTS of good gasser for $500 out there.
If you insist CH Electronics make the full conversion |
+1
Trouble with the internet again?
Just trouble with guys like you. I on purpose sign off with Capt,n No one else complains !
| All times are GMT -8. The time now is 03:47 PM. |
