XXXXXXXXXXXXXXX
flywheels
There are two ways, that should help, combine them, and you should be able to figure it out.
1. The flywheels probably have a heavy part (point on perimeter) to them. Put the engines at TDC, and see it you can fit the heavy part of the flywheel opposite TDC. Usually the heavy part is an external balancing of the engine, to counter the reciprocating mass (piston and rod). If the solid/heavy part is just a counter to a heavy stell insert, and the flywheel is neatrally balanced, then obviously that won't work. 2. The flywheels will have a magnet or a piece of steel/iron in them, to induce current when passing the magneto. See if either fits so that that happens when piston approaches or reaches TDC. If both tests above come really close with either flywheel, I don't know what to do. DKjens |
high,
Try 2 more tests. 1) are they the same diameter? If not, they will only fit under the coils if they are on the correct engines. 2) are the key slots in the same position? I don't know if manufacturers have a standard key position or not, but if the key slot is not at the same position on the shaft when the piston is at TDC, you might be able to extrapolate which flywheel is which by comparing the key position relative to the magnets. Good luck! BTW - I assume the shaft tapers are the same ... that would be too easy. Bedford |
YEP
PRAY AND SWAP THEM AND INCLUDE SKYHOOKS AND TRADE THEM TO ME FOR 3 NIB KITS |
YEP
PRAY SWAP THEM AND INCLUDE SKYHOOKS AND TRADE THEM TO ME FOR 3 NIB KITS |
| All times are GMT -8. The time now is 06:11 AM. |
