RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Kroma 180i (https://www.rcuniverse.com/forum/gas-engines-142/3477458-kroma-180i.html)
Camel 10-21-2005 05:24 PM
Kroma 180i
Anyone tried one? 19hp 6000rpm on a 32 x 10 for 8.25lbs, sounds good.
flyinrazrback 10-21-2005 05:32 PM
RE: Kroma 180i
todd blose on here is an importer of them, he is running one on a dr hobbies. 3.0m extra, has good things to say about them
Camel 10-21-2005 05:35 PM
RE: Kroma 180i
Thanks, you out there Todd, what's it like? worth a risk vs the DA record?[>:]
torqmeister 10-21-2005 08:22 PM
RE: Kroma 180i
I've seen one on a DR Hobbies 3.0 meter Extra, & it was absolutely awesome. If I were in the market for a 150cc, this is the engine I would buy.
Fred 10-28-2005 01:34 PM
RE: Kroma 180i
I seen Todd fly his 180 last weekend at an IMAC here is what I think about it ,,It started easy and at idle it looks smooth and sounds like a dragster .(it had stock mufflers).he had a Bolly 32x10 on it and it would bark so lound it woke my dead grandmother,,he said they are still trying to find a suitable prop for it ,,I know that 32x10 was no competetion for it ,,He flew at half throttle or less ,with more than enough power I will be keeping a watch on this engine ,,Todd maybe onto somthing with this ,,Time will tell though,, IMHOP
toddblose 11-03-2005 10:58 AM
RE: Kroma 180i
Camel,
I have 11 gallons through the 180 and the power is unbelievable.
We are trying some different props to find the right size, and we are in the process
of putting my 180 on cans. I believe the motor is going to be very strong and dependable
drmercier 11-03-2005 02:19 PM
RE: Kroma 180i
You can go to www.drhobbies.com and see a video of the Kroma 180 flying on a 40% DR Extra.
Diablo-RCU 11-03-2005 07:52 PM
RE: Kroma 180i
How's the Kroma-100 run.
Prop and rpm?
Flip and Fly 11-03-2005 08:35 PM
RE: Kroma 180i
Looks interesting, and who makes them? Will be interested to see the rest of the line. It sure is great to see so many fine motors out there:D
Dangerous Dan 05-04-2006 10:54 AM
RE: Kroma 180i
WOW Looks like it is only a couple oz more than a DA 150! What kind of ignition does it come with? What is the recomended Oil/Fuel breakin/Flying? What Hub bolt pattern does it have?
Dan P
Goggles 05-05-2006 12:14 AM
RE: Kroma 180i
Check here for more info....[link=http://www.rcuniverse.com/forum/m_4220535/tm.htm]http://www.rcuniverse.com/forum/m_4220535/tm.htm[/link]
