Quadra 52
I'm looking for information on how to add an ignition switch onto my Quadra 52 engine.
Thank you |
RE: Quadra 52
There should be an unused lug coming out of the top of the coil..Grounding this lug will kill the engine..
RE: Quadra 52
Thanks for the information.
So I hook-up the switch to this plug? If so, where does the 2nd wire from the switch go to? Thanks, Ty |
RE: Quadra 52
Ground to engine case.
| All times are GMT -8. The time now is 08:44 AM. |
