help!DA 50 plug tip
Im cleaning the plug on my DA 50. i need to know what the distance between the tip n base of the plug shud be. pls help!
RE: help!DA 50 plug tip
This is for the NGK CM-6. Not sure if all plugs are the same gap.
.018 - .020 inches .45-.50 mm |
thanks. at least i hv a benchmark
| All times are GMT -8. The time now is 09:18 PM. |
