DA50 ignition switch
Hey guys, am I ok just using a heavy duty switch harness between the battery and the ignition, as well as a choke servo for adequite kill switchage??
RE: DA50 ignition switch
ORIGINAL: budgetdude Hey guys, am I ok just using a heavy duty switch harness between the battery and the ignition, as well as a choke servo for adequite kill switchage?? I personally use the Smart-Fly optical kill and it only weighs 1 ounce |
ORIGINAL: bubbagates I personally use the Smart-Fly optical kill and it only weighs 1 ounce |
Ok so thats 2 votes for the SF.
I appreciate the advice guys but I think I am going with the RCAT: http://www.rcatsystems.com/electronics/rc100.php
I mean its 50cc's and I dont need all the lights and dual rx BS, and there are bigger glow motors than this thing. |
ME too.
Schweet!! Having said that though, believe me, when I finish my 34%er with 2 rx and 3 batts and the whole 9 nine yards I will probably------------still not use the SF switch. Just kidding!! Or am I, ok I will.
ORIGINAL: budgetdude Schweet!! Having said that though, believe me, when I finish my 34%er with 2 rx and 3 batts and the whole 9 nine yards I will probably------------still not use the SF switch. Just kidding!! Or am I, ok I will. I think RCATS also has some kind of optical kill :D The whole idea is you want to be able to kill the engine that is not related to anything that has a linkage to it. There is even a setup on Towers site that uses a micro switch and a servo but it pprobably weighs something like 3 or 4 ounces. The weight and simplicity of the optical switches are why we use them. |
There is an rcats that does have fiberoptics but they have a nice little one that doesnt. You just put it inline with the ignition wiring and it lets you shut down with a trans switch, or power failure.
| All times are GMT -8. The time now is 10:44 PM. |
