RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   DA 50 midrange setup (https://www.rcuniverse.com/forum/gas-engines-142/3764877-da-50-midrange-setup.html)
RCFREEK 01-12-2006 09:25 AM
Im running 2 turns on the high end and 1.25 on the low end. My engine seems to blubber in the mid-throttle range, but the transition is ok and i dont get the power i need. If i take the low end to 1 rotation the power n transition are awesome, but the engine quits n i think its due to being lean. secondly, on extended downlines, my engine quits. Is it becoz it starves with the clunkline being at the back, or is is due to being overly rich? pls advise.
I fly at 700ft asl and am using a 22x8 msc prop. I have 25 tanks of fuel thru it as of now. oil blend is 33:1
DKjens 01-12-2006 12:36 PM
RE: DA 50 midrange setup
Your engine is not nearly close to being run in. Don't lean it out yet to where you get perfect transition and max rpm - 200-300, burn 5 gallons of gas first, switch to synthetic, and then set your needles. As long as the engine is breaking in, set your flying idle a bit high, and both low and high needles on the rich side. As the engine breaks in, you can gradually lean it out.
DKjens
famousdave 01-12-2006 02:32 PM
Here's what I do for any DA50 I get my hands on. I have hundreds of flights on them and the one Dave had looked at he said was wearing perfectly and running very clean.
Despite what people expect, DA50s don't run that great out of the box.. the midrange is not all that good and the idle is rocky. Dead sticks at low throttle are not uncommon if the needles are even just slightly rich (which is where everyone thinks they need to set them to run a new engine for break in) ... here's what I do to minimize the pain:
Misconception #1 - low end needs to be rich to prevent overheating. Not true, you want to lean the low end as much as possible the only challenge here will be keeping the engine running or from dead sticking.
Misconception #2 - DA's take a long time to break in.. NOT 2 gallons is more than enough.
Here's a tried and true recipe for getting the most out of your DA50>
1> Run BelRay S2 or Lawnboy Petroleum 2-Stroke oil 32:1 Regular Unleaded (don't use premium)
2> Use a 22x8 MenzS or NX wood prop (you don't want a large load on a new engine)
3> Set the high needle for highest RPM, then back off 300 RPM (you can do this by ear, 300 RPM is pretty noticeable)
4> Set the low needle so the engine just barely stumbles from idle to WOT during a rapid transition, once this point is attained, richen the low needle by the width of one screwdriver blade at a time until the hesitation stops
5> Check WOT again, tune for max RPM, then back off by 300
If you get this right, the midrange won't be too bad, and you won't have the "die at idle" or "die at touchdown" problems most people run into with these engines DA's are extremely sensitive to needle settings.
You may have to deal with a little higher idle at first until you get a gallon or two through it, after the first gallon its OK to start lowering the idle, by the second gallon, you should be able to final tune the engine and not have to touch it again.
During this period also just FLY the airplane. Avoid prolonged WOT use, and especially hovers and high stall events that will allow heat to build up in the cowl. The first 15 minutes of an engine's life is the most critical!! Keep it cool!
After TWO gallons, it is quite safe to switch over to BelRay H1R full synthetic, run that at 50:1 Running break in oil more than 2 gallons in these engines is a waste and just lays down heavy carbon deposits where you don't want them. My original DA50 has 500 flights on it and is still running like new. I have never touched the needles since my final tune after 2 gallons. Best running engine I have ever owned (well, OK, I like my 3W QQ106 too...)
DP
RCFREEK 01-13-2006 10:22 AM
i use 2 stroke motorcycle oil, which, i guess is not synthetic. Is that ok? ill try out the needle setting as u recommend and let u know asap. thanks
famousdave 01-13-2006 10:40 AM
ORIGINAL: RCFREEK
There are two kinds of two stroke motorcycle oil - synthetic and non-synthetic. Non-Synthetic is distilled from raw crude oil (i.e. its a direct product of crude oil) Synthetic is synthesized from the components of crude oil (amongst other things).
If you have limited access to oils, a good two stroke motorcycle oil of either type is fine. I know many people who run synthetic oil in their engines from day one and they work and last just as long as those who use non-synthetic first and switch.
Bottom line - if you are using a good oil (i.e. Motorex, Bel-Ray, or other name brands) you will be fine, just make sure you mix at the recommended ratio on the bottle. Non -synthetics 32:1 and Sythetics vary between 32:1 and 100:1 so you have to be careful.
DP
