RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Cleaning a gas engine. (https://www.rcuniverse.com/forum/gas-engines-142/3810045-cleaning-gas-engine.html)
Pelle Gris 01-22-2006 05:23 PM
Hello guys.
I´m putting a new crankshaft into my G-62, and since I will have to disassemble the engine to do that, I would like to make it look new at the same time..:D
Especially the cylinder has collected quite a lot of dead bugs and other crap between the fins.
What do you all recommend I use for cleaning it? Gas, acetone, soap????
Nogyro 01-22-2006 06:05 PM
RE: Cleaning a gas engine.
I've always just used gasoline. It will cut an oil that has accumulated on there as well.
GoeKeli 01-22-2006 06:15 PM
Kerosene is my favorite!
joe
Pelle Gris 01-22-2006 07:05 PM
Thanks... Although I´m not completely sure what Kerosene is. Is it the same that are used for fuel in lamps and heaters? I have once used that for cleaning the rims of my motorcycle, and it seemed to do a good job.
If I can´t find any kerosene I´m going to try regular gas.
pe reivers 01-23-2006 08:31 AM
Kerosene is petroleum, or lamp oil (the wick lamp type, not the coleman gas bulb type).
Pelle Gris 01-23-2006 01:03 PM
Thanks a lot.. I will try that.
