RCU Forums
-   Gas Engines (https://www.rcuniverse.com/forum/gas-engines-142/)
-   -   Prop balancer for large props (https://www.rcuniverse.com/forum/gas-engines-142/3973341-prop-balancer-large-props.html)
rc bugman 02-28-2006 06:07 PM
Guys,
I need some recommendations for a prop balancer for large props. Prop sizes from 22" to 34 "
Thanks Elson
Rcpilot 02-28-2006 06:11 PM
RE: Prop balancer for large props
This one works really good.
You can't tell from the advertised pictures, but you can set it up to let the prop hang off the side of the bench and then actually spin the prop around a full 360* circle and wait for it to stop.
It works very well. Well built. Simple to assemble and use.
http://www2.towerhobbies.com/cgi-bin...?&I=LXD712&P=7
bubbagates 02-28-2006 06:20 PM
I agree with Rcpilet
It's the one I use and I know at least a dozen others that use it also
JoeAirPort 02-28-2006 06:44 PM
Yep that's the one you want. Great for big props. I have a magnetic one that use for smaller props.
off2fly 02-28-2006 07:22 PM
Can't beat a Dubro! Bugman did you ever try the Bel Rey Mc-1 oil?I thought I read that you were going to test or try it:D
Big_Bird 02-28-2006 07:25 PM
Elson, one more vote for the DuBro. Have used it for a long time.
rc bugman 02-28-2006 08:08 PM
off2fly,
We tested Belray MC-1 in our oil test a year ago.
Results:
The only oil which did not form carbon on the piston
Since the oil does not burn, fuel consumption was increased by about 15%
Thanks for the recommendation on a prop balancer. I will purchase one the next time I buy from tower.
Elson
off2fly 02-28-2006 08:14 PM
Ok, I thought you just tested the Bel Rey H1R, Imust be confused as usual.Thank's, Btw Which oil did you decide to use and is it panning out? :D
rc bugman 02-28-2006 08:17 PM
duh!
You are right. I am confused. We did not test Bel ray mc-1
my error.
Elson
off2fly 02-28-2006 08:21 PM
Ok I thougt you were planning to or something,I remember you mentioning it.I'm going to try and find that old thread and reread.I'm surprised your neibors did'nt shoot you running all those test! LOL!
tail strike 03-01-2006 08:21 PM
What they all said about the DuBro balancer the best!
ORIGINAL: Big_Bird
